More Stopping Power
Posted 22 May 2012 - 08:31 AM
Posted 22 May 2012 - 09:50 AM
EBC brake pads! I put them on my 2007 range rover sport with drilled and slotted rotors and it made a huge difference. I think Synergy sells an upgraded kit just for our trucks too.
http://www.shop.syne...e-EBCBRAKES.htm
Edited by atvspeed4, 22 May 2012 - 09:52 AM.
Posted 22 May 2012 - 04:16 PM
Pull your ABS fuse then slam on the brakes, you'll find out.
Posted 22 May 2012 - 06:58 PM
Posted 22 May 2012 - 07:54 PM
I was only saying that so you could see what happens when you have full braking power not limited to traction.
And since you are SFA that doesn't apply. You are probably going to need to post this in the SFA section, since they don't really pay attention to other sections.
Posted 22 May 2012 - 09:05 PM
Edited by gsmobile2007, 22 May 2012 - 09:22 PM.
Posted 23 May 2012 - 01:01 AM
http://shop.savvyoff...p;categoryId=15
Uses off the shelf parts.
Posted 23 May 2012 - 06:31 AM
What is your current setup?
Posted 23 May 2012 - 07:45 AM
Stock booster/master
Still runs through ABS mod(no ABS though)
Jeep TJ disk brakes up front and stock disk in rear
Im going to look into the suburban booster, if I can find the thread for it.
Posted 23 May 2012 - 08:25 AM
Removing the ABS module is super simple and highly recommended. You just need to run a couple lines and put in a T for the front lines. You have every reason why you SHOULD be doing this and zero reasons why not to.
I would also suggest you add an adjustable proportioning valve inline on the rear line. Wilwood makes one that is like $30. Very easy install too.
I would do both of these before you mess with the booster.
Posted 23 May 2012 - 09:06 AM
Chris this pvalve?
http://www.jegs.com/...0-8419/10002/-1
Edited by mondo8205, 23 May 2012 - 09:10 AM.
Posted 28 May 2012 - 01:09 AM
Does anybody on this forum have experience with this adjustment? I have done it on my Bronco when installing a new brake booster. One caution: it is possible to make the pushrod too long which would preload the pressure of the braking system.
Posted 28 May 2012 - 01:15 AM
The biggest gain comes from improved pads & rotors, however. The EBC setup will offer less noise and dust, longer life, and substantially improved stopping distance.
D'oh. Keep forgetting you're SFA. That link above is for stock-height trucks, although if you're interested in an EBC setup, send me a PM with the specifics of your setup, and I'll see what I can find for you through our suppliers.
Edited by jwwaldschmidt, 28 May 2012 - 01:18 AM.
Posted 28 May 2012 - 07:10 AM
Time for noob to go read up on master cylinder basics. Pressure decreases as bore size increases. A large bore MC with stockish parts would give way less braking power.
Posted 28 May 2012 - 12:13 PM
Posted 28 May 2012 - 01:09 PM
http://www.automedia...pht20080501gh/1
That doesn't make 100% sense to me, but I've never torn apart a M/C, so I'm just drawing pictures in my head of how I think they work internally. I need to rebuild the one for my Mustang, that would be a good time for me to learn.
Posted 29 May 2012 - 08:01 AM
Ill also look into this. I might do a combination of this and removing the abs module.
Posted 29 May 2012 - 08:45 AM
