Fuse Question
Started by BLACK96regcabHighrider, May 15 2012 11:48 AM
10 replies to this topic
Posted 15 May 2012 - 11:48 AM
Been putting this off for way too long… I’ve never been good at audio or electrical stuff, but I have a quick question that I’m sure audio guys could answer in a second.
I have an sub/amp in my truck and had an inline fuse between the positive battery terminal and the amp. It fell out one day and I just never felt like picking one up, a loud stereo isn’t a necessity to me. Well now I feel like hooking it back up so it at least sees some use.
How do I know what size fuse to get? I was told to add up the fuses on the side of my amp and try to get a fuse as close that that as I can but stay under. True?
Posted 15 May 2012 - 12:53 PM
I usually use 30a-60a fuses in my stereos. If it's not too big of a system you should be fine with a 30a.
Posted 15 May 2012 - 01:00 PM
Look up or call the manufacturer and tell them the model number. They'll be glad to inform you what size inline fuse it will require. Some systems are different. Mine requires a 100 amp fuse which isn't available at Walmart...if you know what I mean.
EDIT:
I just did a quick search on Crutchfield for my make and model and below in the description it tells exactly what size fuse is required. Here's mine for example.
http://www.crutchfie...r-bd1000-1.html
EDIT:
Edited by N.J.C., 15 May 2012 - 01:07 PM.
Posted 15 May 2012 - 01:08 PM
go by the guage of wire your using.
8Ga - 40A
4ga - 60-80a
0-2ga - 100-120a
8Ga - 40A
4ga - 60-80a
0-2ga - 100-120a
Posted 15 May 2012 - 01:10 PM
QUOTE (RareBreedZ @ May 15 2012, 01:08 PM) <{POST_SNAPBACK}>
8Ga - 40A
4ga - 60-80a
0-2ga - 100-120a
8Ga - 40A
4ga - 60-80a
0-2ga - 100-120a
Not always true. Mine allows use of a 4 AWG wire but requires at least a 100 amp fuse. Go by the manufacturers specs.
Posted 15 May 2012 - 02:57 PM
Thanks for the info guys. I'll look it up by mfg and go from there. I know NOTHING when it comes to audio.
To prove how much I don't pay attention to audio, I couldn't even tell you what kind of sub's I have.
Thought about selling the amp and sub to regain some of the spacious interior a single cab offers
, but figured I'd try it out once more.
Posted 15 May 2012 - 04:39 PM
Here's the basic info we need:
1. What is the thickness (gauge) of the wire you are using?
2. How long is the wire?
3. What have you hooked up to it? Amps usually have a fuse on them ... look at those fuses and report their rating.
If you don't feel like doing any of this, you can start with a 30A fuse .. if that blows, go up to 40 or 50. More than that and you might want to make sure your wires can handle it
Posted 17 May 2012 - 02:28 PM
I'd go with 50A (or 60A) .. I seriously doubt you'll blow a 50A though ... the 2x30s indicate it could have a max draw of 60amps.
Posted 17 May 2012 - 02:31 PM
QUOTE (Seapahn @ May 17 2012, 02:28 PM) <{POST_SNAPBACK}>
Thanks, I'll pick up a 50A first. Shows how much I know about electrical/audio haha.
Posted 18 May 2012 - 06:59 AM
50A did the trick so far. Thanks for the input!
