Oil Pressure
Posted 03 April 2012 - 07:35 PM
Posted 03 April 2012 - 07:52 PM
Old school trick is to run thicker oil. Others will disagree.
Posted 03 April 2012 - 07:54 PM
Posted 04 April 2012 - 08:07 PM
Posted 04 April 2012 - 08:30 PM
I'm at about 25-40 idle warm, but it increases with rpm. I have put 60k on it with no issues.
I wouldn't worry about it. From what I have read, its a common thing with all chevy engines.
Posted 04 April 2012 - 10:14 PM
Posted 05 April 2012 - 01:28 AM
If you're running OEM spec oil, I wouldn't worry about it too much. Pressure should go down slowly with more miles, as tolerances are slowly worn out. As long as you have some oil pressure, you should be fine.
Posted 05 April 2012 - 08:08 PM
Posted 12 April 2012 - 11:23 PM
Steve
Posted 12 April 2012 - 11:26 PM
I haven't seen a single truck that would 55PSI of oil pressure at redline. That doesn't seem right to me, at all.
I've seen SBC's idle at 5PSI all day and never have issues.
Posted 13 April 2012 - 12:41 PM
Steve
Posted 13 April 2012 - 12:55 PM
Is something wrong with mathmatical ability.
10 per thousand is 1 per 100.
550 idle would 5.5lbs.
The question was minimums.
Posted 13 April 2012 - 01:30 PM
Steve
Posted 13 April 2012 - 03:36 PM
Really? I don't remember exact numbers, but I think I'm close to that.
Posted 13 April 2012 - 04:20 PM
Does 60 at 4500rpm
Posted 13 April 2012 - 08:34 PM
Posted 14 April 2012 - 05:05 PM
Posted 14 April 2012 - 06:07 PM
Posted 14 April 2012 - 10:05 PM
The PCM has no control over oil pressure. The oil pump is directly driven by the cam and is not variable. A t-stat that is stuck open or closed or one that is too cold does not have any effect on oil pressure. Temperature is the only thing that can affect oil pressure. The hotter the oil, the lower the pressure, and vise versa.
Steve
Posted 15 April 2012 - 09:17 AM
I'm at 188k miles, running Mobil 1 10w30: Idle oil pressure is 40 cold, 30ish hot, and at 2200 rpm it's at 60 psi...
It was about the same with the 5w30...
