I need heeeelllpppp
30 replies to this topic
#1 TRL09
TRL09
  • Sponsored Member
  • 41 posts
Posted 20 March 2012 - 09:27 PM
long story short Im in the process of doing a motor swap, 4.3 to 4.3 story later, at the current moment I have the oil pan detached from the block and the block lifted a good 3 - 5 inches, however, I cant find any diagrams to access the rest of the bolts from the block to the tranny!! can somebody PLEEAAASSEEE point me in the right direction??
#2 rustyg
rustyg
    Wants 26 Bacons Now
  • 3,351 posts
  • Interests:Fixin' broke stuff. Drag racing with my beautiful fiance.
Posted 21 March 2012 - 04:35 AM
These here bolts?
#3 Postmond
Postmond
  • 296 posts
  • Interests:Hunting, fishing, OU football
Posted 21 March 2012 - 06:11 AM
If it is an auto trans you will also have to go through the starter hole and unbolt the converter from the flywheel. You will have to manually turn the engine to access all the bolts.
#4 N2O_ZR2
  • 22,094 posts
Posted 21 March 2012 - 10:44 AM
Why do you have the pan off, and why do you have the motor lifted?
#5 jwwaldschmidt
  • 14,815 posts
Posted 21 March 2012 - 10:46 AM
QUOTE (N2O_ZR2 @ Mar 21 2012, 10:44 AM) <{POST_SNAPBACK}>
He took the pan off without even getting under the truck -
#6 N2O_ZR2
  • 22,094 posts
Posted 21 March 2012 - 11:01 AM
Holy fuck, how did he manage that?
#7 mountain_tamer82
mountain_tamer82
    Waiting for things that 'pop up'
  • 2,118 posts
Posted 21 March 2012 - 11:15 AM
" Im offically proof all asians aren't smart..."
When the hell did asians start driving ZR2's??? This is totally new to me... is this even authorized?? Were are all the adults??
#8 jwwaldschmidt
  • 14,815 posts
Posted 21 March 2012 - 11:16 AM
QUOTE (N2O_ZR2 @ Mar 21 2012, 11:01 AM) <{POST_SNAPBACK}>
It's had a knock for quite a while, it wasn't real high on his priority list, apparently.
Claims he was driving down the highway, 65MPH when everything "seized up".
He's officially more of an engine-killer than Josh. This is the second motor in 3 years or so that he's thrown a rod in.
Edited by jwwaldschmidt, 21 March 2012 - 11:17 AM.
#9 jwwaldschmidt
  • 14,815 posts
QUOTE (mountain_tamer82 @ Mar 21 2012, 11:15 AM) <{POST_SNAPBACK}>
They haven't started driving ZR2's just yet... his is a regular 4x4 Jimmy. tongue.gif
#10 VahomboyZR2
VahomboyZR2
  • 141 posts
Posted 21 March 2012 - 11:41 AM
A little JB Weld and it will be as good as new.
#11 zr2indiana
zr2indiana
    a sayin
  • 2,648 posts
  • Interests:Fishing, camping, hiking, hunting
Posted 21 March 2012 - 11:42 AM
QUOTE (VahomboyZR2 @ Mar 21 2012, 12:41 PM) <{POST_SNAPBACK}>
And a coat of paint
#12 N2O_ZR2
  • 22,094 posts
Posted 21 March 2012 - 12:09 PM
QUOTE (jwwaldschmidt @ Mar 21 2012, 12:16 PM) <{POST_SNAPBACK}>
That's more than just a rod knock, I bet that pan was dry as a bone.
Look at the heat marks on the pistons. That is absurd.
#13 jwwaldschmidt
  • 14,815 posts
Posted 21 March 2012 - 12:12 PM
QUOTE (N2O_ZR2 @ Mar 21 2012, 12:09 PM) <{POST_SNAPBACK}>
You're preaching to the choir...
#14 mountain_tamer82
mountain_tamer82
  • 2,118 posts
Posted 21 March 2012 - 12:14 PM
QUOTE (jwwaldschmidt @ Mar 21 2012, 11:16 AM) <{POST_SNAPBACK}>
Oh thank god!! I was worried for a minute there....
X2.... I'm with you on a dry motor..... You don't have a motor explode like that and have NO signs of oil splatter!! Crazyyyy....
#15 rustyg
rustyg
    Wants 26 Bacons Now
  • 3,351 posts
Posted 21 March 2012 - 12:20 PM
Holy fuck
x2 on that!!
#16 67Truckin
67Truckin
  • 415 posts
Posted 21 March 2012 - 12:31 PM
Meh, new timing chain and gear set, gaskets, oil and its good as new again. Probably get better gas mileage since it weighs less too!
#17 jwwaldschmidt
  • 14,815 posts
Posted 21 March 2012 - 12:32 PM
QUOTE (67Truckin @ Mar 21 2012, 12:31 PM) <{POST_SNAPBACK}>
I'll cut some holes in the floorboard so he can help out on the uphill stretches. lol.gif
#18 OCwrencher
OCwrencher
  • 175 posts
Posted 21 March 2012 - 10:50 PM
Aside from the obvious signs of neglect..... a little help to the OP. Remove the trans x-member, get the engine block as low as possible to original height, droop the trans, and use a 36" extension and a 15mm swivel socket to remove the trans to block bolts. And as stated above, remove the starter and unbolt the torque converter from the flex plate (do this before trying to remove trans to block bolts).
#19 jackn7
jackn7
  • 132 posts
Posted 22 March 2012 - 12:37 AM
QUOTE (zr2indiana @ Mar 21 2012, 09:42 AM) <{POST_SNAPBACK}>
And a coat of paint
Don't forget the duct tape. You can fix anything with duct tape!
#20 Zr2freak316
Zr2freak316
  • Exterminated
  • 5,556 posts
Posted 22 March 2012 - 01:03 AM
Holy Fuck X676273! You abused the Hell outta that motor. I bet 20 bucks it maybe had a drop of oil, if that. Keep up on your shit man. That thing in your glove box tells you when you should change oil and what not.
But if you wanna put your oil pan back in just undo your motor mounts( that's what holds the motor to the frame), and jack the engine up as far as it will go, and just hit the oil pan with a BFH. Then a few tack welfare and duck tape should make it all better. lol.gif
