Hood insulation pad
18 replies to this topic
#1 Wags
Wags
  • 330 posts
Posted 02 February 2012 - 05:42 PM
Just seeing who has the fiberglass type insulation pad on the underside of their hood on still? I have mine on, but it is starting to tear a lot, and it is a major dust collector. I was going to take it off and throw it away, but in the winter it does seem to help keep the engine a bit warmer right after driving when parked.
If I do toss it I would like to maybe get another one in the future, but haven't seen any for sale. I might be looking for a wrong part. Anyone know the correct part name or number?
#2 N2O_ZR2
  • 22,138 posts
Posted 02 February 2012 - 05:53 PM
QUOTE (Wags @ Feb 2 2012, 05:42 PM) <{POST_SNAPBACK}>
It also keeps you engine bay hotter in the summer.
#3 67Truckin
67Truckin
  • 415 posts
Posted 02 February 2012 - 06:12 PM
Functional cowl hood on mine. Toss the insulation. It's only there to muffle engine noises.
#4 the.clemons
the.clemons
  • 2,480 posts
Posted 02 February 2012 - 07:40 PM
Isn't it fire retardant? Or just plain retarded? I tore mine out.
#5 ducksface
Posted 02 February 2012 - 07:48 PM
Mine is there. No reason to have it, no reason to take it out. It lives a happy uninvolved life under there.
#6 ZL1power69
ZL1power69
  • 1,212 posts
Posted 02 February 2012 - 08:20 PM
My stock hood still has it but the center was starting to come apart and the intake hat was rubbing a hole in it. Switched to Gen II hood so I no longer use one. Only place I know that sells them is LMC.
#7 N2O_ZR2
  • 22,138 posts
Posted 02 February 2012 - 08:22 PM
If there is a hole in your hood insulation that is usually a sign of separated motor mounts.
#8 RareBreedZ
RareBreedZ
  • 1,715 posts
Posted 03 February 2012 - 12:49 AM
I was taught that the purpose of it was to:
1). Fire retardant IE: it will fall on the engine and smother the fire.
2). Quite down the engine bay.
#9 bubba68ss
bubba68ss
  • 557 posts
  • Interests:Guitar, flying, building engines, dinking around with the truck
Posted 03 February 2012 - 04:36 AM
QUOTE (RareBreedZ @ Feb 2 2012, 09:49 PM) <{POST_SNAPBACK}>
sounds good to me
#10 ZL1power69
ZL1power69
  • 1,212 posts
Posted 03 February 2012 - 09:28 AM
QUOTE (N2O_ZR2 @ Feb 2 2012, 08:22 PM) <{POST_SNAPBACK}>
Correct, mounts were shot and were replaced.
#11 N2O_ZR2
  • 22,138 posts
Posted 03 February 2012 - 02:42 PM
QUOTE (RareBreedZ @ Feb 3 2012, 12:49 AM) <{POST_SNAPBACK}>
That's no fun.
QUOTE (ZL1power69 @ Feb 3 2012, 09:28 AM) <{POST_SNAPBACK}>
#12 ReDnekZ
ReDnekZ
  • 3,347 posts
  • Interests:Traditional archery, trucks, duck hunting
Posted 03 February 2012 - 02:47 PM
QUOTE (ZL1power69 @ Feb 3 2012, 08:28 AM) <{POST_SNAPBACK}>
jeez every Chevy truck I've ever owned has had a hole in the center. maybe it's time I replace the mounts on the Z and Silverado
#13 bigblockbilly
bigblockbilly
  • 1,273 posts
  • Interests:Drag racing, low riders and off roading
Posted 03 February 2012 - 04:13 PM
QUOTE (ducksface @ Feb 2 2012, 07:48 PM) <{POST_SNAPBACK}>
x2.
#14 jwwaldschmidt
  • 14,830 posts
Posted 03 February 2012 - 04:35 PM
Motor mounts are extremely common to go bad on these, I've seen very few without the rub in the middle. Energy Suspension mounts should fix you right up, and you'll never have to worry again.
Edited by jwwaldschmidt, 03 February 2012 - 04:37 PM.
#15 N2O_ZR2
  • 22,138 posts
Posted 03 February 2012 - 04:38 PM
QUOTE (jwwaldschmidt @ Feb 3 2012, 04:35 PM) <{POST_SNAPBACK}>
Is there someplace that would happen to sell a motor mount that doesn't separate? wink.gif
#16 jwwaldschmidt
  • 14,830 posts
QUOTE (N2O_ZR2 @ Feb 3 2012, 03:38 PM) <{POST_SNAPBACK}>
Already fixed it, thanks though.
#17 Black Angel
Black Angel
  • 315 posts
  • Interests:upgrading my blazer
Posted 03 February 2012 - 07:01 PM
i have a cowl hood on mine, so i just cut out a section in the middle and left it at that.
#18 cknaffle
  • 15,979 posts
Posted 04 February 2012 - 11:07 PM
Its more of a sound deadener than an insulation. No reason to keep it there if you don't mind a little extra noise.
#19 Blackhighrider
Blackhighrider
    Pirate
  • 6,902 posts
Posted 05 February 2012 - 11:55 AM
I left mine out whenever I put my cowl hood on a couple years ago. No negative effects so far
