Starting problem?
#21
Posted 23 November 2011 - 09:48 PM
#22
Posted 23 November 2011 - 10:11 PM
#23
Posted 23 November 2011 - 10:20 PM
#24
Posted 24 November 2011 - 06:52 PM
Yea I've checked everything a hundred times now. Maybe the sensor is bad and needs replaced?
#25
Posted 24 November 2011 - 09:06 PM
A massive vacuum leak could be preventing the engine from starting. A large enough vacuum leak will lean out the air/fuel ratio to such an extent that the mixture won't ignite. An EGR valve that is stuck wide open, a disconnected PCV hose, loose vacuum hose for the power brake booster, or similar leak could be the culprit. Check all vacuum connections and listen for unusual sucking noises while cranking.
The timing chain may have broken or slipped. Either type of problem can be diagnosed by doing a compression check and/or removing a valve cover and watching for valve movement when the engine is cranked.
#26
Posted 24 November 2011 - 09:09 PM
#27
Posted 09 December 2011 - 11:12 PM
#28
Posted 10 December 2011 - 05:16 AM
#29
Posted 10 December 2011 - 03:23 PM
I'm thinking its out of time, I'm getting bad back fire a lot now. It will randomly try and start but then dies out after a few seconds. I just need to take the time and break it down to make sure it didn't jump time.
#30
Posted 12 December 2011 - 12:53 AM
Yeah could be a timing chain problem. Distributor is in correct?
The MAP sensor has an effect on timing and will cause the vehicle to die as soon as started.
Edited by Bobbing, 12 December 2011 - 10:19 AM.
#31
Posted 12 December 2011 - 10:59 PM
I swapped out the MAP sensor on my buddies Z and still nothing and he even ran his with mine no problem. I'm getting a lot of back firing when I try and start it now so I'm running out of ideas except for a timing issue. The distributor was never removed or anything just replaced the button and cap as well as new plugs and wires. The motor does have a lot of miles so I'm hoping maybe the guide or tensioner may have broke. I'm going to have to take a warm day and break into it and check my timing. If anyone has any other ideas let me know I'm up for trying anything.
#32
Posted 12 December 2011 - 11:15 PM
And the 4.3 doesn't have a guide or tensioner for the timing chain. A worn or cracked distributor gear could also be a possibility.
#33
Posted 13 December 2011 - 12:21 AM
Ah there has been plenty of foam ran through this one. I drained the tank and put 5 gallons on 93 and a can of foam in her when I was trying to figure out my injector problem.
So there is no guide or tensioner? hmm then why the f*#k does advance auto sell one lol. I'm gonna get on checking the main timing first before I tear into the distributor. I sure as hell hope that is not the problem because it is in a crappy place to get to.
I'm getting to the point where I am about to just get another 4.3 and drop in there or get a bare block and throw all the new crap over on it. When I finally discover whats wrong I will be sure to let everyone know what the culprit was.
#34
Posted 13 December 2011 - 12:53 AM
#35
Posted 14 December 2011 - 04:59 AM
#36
Posted 14 December 2011 - 05:36 AM
It stays at 60 for about 15-20secs then it drops back off....Could it be the fuel pressure regulator?
The Fuel Pressure Gauge's needle will drop 5 PSI only and remain steady for at least one full minute.
In a system where the Fuel Pressure Regulator or Fuel Lines are not leaking.. the pressure should hold steady (not dropping to zero) for about 5 minutes.
CASE 1: The Fuel Pressure Gauge's needle DID NOT drop down to 0 PSI immediately after the Key was turned to the Off position: This tells you that the Fuel Pressure Regulator and the other components that are part of the Fuel Injector Assembly are NOT BAD.
CASE 2: The Fuel Pressure Gauge's needle DID drop down to 0 PSI immediately after the Key was turned to the Off position: This tells you that there is something leaking inside the Plenum. More than likely, it'll be the Fuel Pressure Regulator
Are you SURE, this is the case, Bobbing? I have read much information regarding fuel pressure and am tired of seeing misinterpreted information. I checked my fuel pressure a few weeks back, and found no indication of this being the problem with my truck. Makes me wonder if my trouble is elsewhere, like possibly in my non-functioning 4-wheel drive, potential inconspicuous, vacuum leak.
#37
Posted 14 December 2011 - 10:26 AM
Yea I order the kit from gmpartsdirect and it took them forever to ship it. Yea you save a pretty good deal but I would have rather spent the extra 200 and had the part within a few days then almost a month. I get strong fuel pressure all the way up to the fuel rail, you can jump the pump over and keep it at a constant 60psi, when you prime the injectors you can hear a rush of fuel. I need to make a new parts list or parts I've checked to eliminate the problem of suggesting the same thing over and over. I appreciate everyone's help and can not wait to get my Z running again so keep the suggestions coming.
#38
Posted 14 December 2011 - 10:44 AM
I had problems out of a bad 4wd acutuator. If you have the money go with a bravada front end or SFA. Then theres the cheap way and remove the battery box and manually lock it in 4wd then cut a piece of wood to fit the gap. Install everything back and boom 4wd when you need it and you can still lock in lock out.
#39
Posted 14 December 2011 - 11:31 AM
Did you start a thread for your problem?
Yes that is correct info BTW
#40
Posted 14 December 2011 - 11:34 AM
