Budget Rear Bumper Rebuild
45 replies to this topic
#21 jwwaldschmidt
  • 14,827 posts
Posted 18 September 2011 - 11:56 AM
I would avoid putting a fuel tank in the passenger compartment at all costs.
Find a local fab shop, have them give you an estimate. It won't be cheap.
Post up a few pictures of where the Blazer fuel tank is, and how it is mounted. I'm not familiar with it.
#22 QuickSilverAWD
QuickSilverAWD
  • 326 posts
Posted 19 September 2011 - 01:32 AM
While you are at it, take it to a good drift shop or find someone that rents out a fender roller tool. You could throw some much bigger tires on there now without the flares.
#23 Hiddenfarce
Hiddenfarce
  • 602 posts
  • Location:South of the hills thrusting down in the valley
  • Interests:Tinkering
    Vintage Cars and Hot Rods
    Off-roading
    Getting Lost
Posted 19 September 2011 - 12:38 PM
QUOTE (bradicalZR2 @ Sep 17 2011, 04:32 PM) <{POST_SNAPBACK}>
About the charcoal canister, (evaporate emissions right?) i took off the two or so inches of excess metal above it and i was going to flip it onto its side and tack weld a mount for it...i was positioning the metal hoses into the body to get them out of the way and the thicker one snapped...(several curse words) so i took the other two hoses off and positioned em in there, all separate from each other. I had no idea what was about to happen, I started her up...ran fine, revved fine, service engine light DID NOT come on. Not sure what to think, anybody think this will mess with MPG and engine? or am i just not going to be able to pass emissions?
Even though those lines are just for evaporation of fuel, the light may not show until a change in temp or usage. The conditions that set that code off may not be present right now but will happen eventually.
I'd do the same thing you were going to do just replace the plastic tubes with fuel line hose. On some models of blazers they replaced those with rubber hose from the factory. That tubing get brittle and breaks very easily and is a common headache. The dealer charges like $200+ for the replacements lines which includes the aluminum lines back to the tank. When mine broke I just replaced it with the canister-side snap connectors from a junkyard donor and some rubber hose to extend the lines since I just needed more length and did not need to relocate the canister. You could just stick the hose on the nipples on the canister and hose clamp it. Just remember each nipple is a different size so make sure they match up. For this part all 4.3 blazers are the same from probably 1995 to 2005, 2 and 4 doors. If the canister nipple broke then just grab the whole thing form the junk yard for a few bucks.
#24 bradicalZR2
bradicalZR2
  • 162 posts
Posted 20 September 2011 - 01:12 AM
QUOTE (QuickSilverAWD @ Sep 19 2011, 12:32 AM) <{POST_SNAPBACK}>
a fender roller tool? what is that? Oh yeah ive got those 235s on the stock rims for highway/economical...ive got a set of off road rims with some k'ed out 31s...im trying to find some halfway decent 33s off craigslist, do you think 33s would rub? im currently in the process of giving the front end about an inch and a half t bar crank...
#25 bradicalZR2
bradicalZR2
  • 162 posts
Posted 20 September 2011 - 01:13 AM
QUOTE (Hiddenfarce @ Sep 19 2011, 11:38 AM) <{POST_SNAPBACK}>
thank you very much for the info on the evap box...will not having it hurt my engine/power/mpg in any way?
#26 ducksface
Posted 20 September 2011 - 01:23 AM
I had considered doing as you did, but now that I see it I won't be doing it. I'm back to the original plan of a rolled rear pan if the need arises, and custom tube bumper if my tire carrier rips itself off of the truck.
I'm not sure how much angle you gained. Those shackles still hang down quite a bit. I'd be surprised [but I surprise easily] if you gained two degrees, and now you have exposed your tank to a ready puncture. I say this because whatever you bent the rear sheet metal on before will now be up against that tank...or through it.
I'm kind of from the school of 'until I tear it off, no need to take it off'. This varies at times, but that is the general plan.
#27 QuickSilverAWD
QuickSilverAWD
  • 326 posts
Posted 20 September 2011 - 01:39 AM
QUOTE (bradicalZR2 @ Sep 20 2011, 01:12 AM) <{POST_SNAPBACK}>
Considering what you have already done, I would roll the fenders before I considered cranking the t-bars.
Edited by QuickSilverAWD, 20 September 2011 - 01:39 AM.
#28 bradicalZR2
bradicalZR2
  • 162 posts
Posted 21 September 2011 - 12:28 AM
QUOTE (QuickSilverAWD @ Sep 20 2011, 12:39 AM) <{POST_SNAPBACK}>
Thats a pretty snazzy lil device, i dont have much to roll out tho i grinded all the lip off madshoot.gif
#29 bradicalZR2
bradicalZR2
  • 162 posts
Posted 21 September 2011 - 12:30 AM
QUOTE (ducksface @ Sep 20 2011, 12:23 AM) <{POST_SNAPBACK}>
Well your trailer hitch hangs down and out a whole lot, yes i suppose it also serves as a sort of skid plate for the tank but i gained a lot of clearence by taking it all off, ill take some side pictures within the week
#30 bradicalZR2
bradicalZR2
  • 162 posts
Posted 22 September 2011 - 09:16 PM
heres the side pic you guys wanted....
Attached File  IMG00099_20110922_1813.jpg   456.02K   44 downloads
also heres a pic of my bumper and trailer hitch keeping me from ascending a fins and things slickrock in moab
Attached File  223168_2052708961053_1344409273_2407298_5066102_n.jpg   81.41K   63 downloads
#31 Jamaroon
Jamaroon
  • 500 posts
Posted 22 September 2011 - 10:23 PM
thanks for the pic!
#32 bradicalZR2
bradicalZR2
  • 162 posts
Posted 22 September 2011 - 11:06 PM
QUOTE (Jamaroon @ Sep 22 2011, 09:23 PM) <{POST_SNAPBACK}>
thanks for the pic!
you got it man
#33 Highrider24/7
Highrider24/7
    CONFIRMED: Gay and loving it!
  • 2,154 posts
  • Gender:Female
  • Interests:Off-roading
Posted 06 October 2011 - 12:23 PM
I really like the custom bumper that clemson put up - im going to get a quote on how much this would cost to actautlly do. I love that look!
Edited by Highrider24/7, 06 October 2011 - 12:24 PM.
#34 sapperb
sapperb
  • 316 posts
Posted 20 January 2012 - 10:52 PM
QUOTE (the.clemons @ Sep 16 2011, 10:13 PM) <{POST_SNAPBACK}>
I like this trim
I am so dig'n this bumpa....
#35 bigblockbilly
bigblockbilly
  • 1,273 posts
  • Interests:Drag racing, low riders and off roading
Posted 24 April 2012 - 08:33 PM
QUOTE (sapperb @ Jan 20 2012, 11:52 PM) <{POST_SNAPBACK}>
I like this trim
x2.
I'd like to do this to my Blazer2 with the addition of a split swingout tire carrier, jerrycan, gear mount mount.
Problem is the Blazers lower plastic extends back from the quarter panels like this.
Anyone know if pickup plastic will fit on a Blazer2?
Attached File  8308988_1.jpg   57.84K   17 downloads
#36 N2O_ZR2
  • 22,118 posts
Posted 24 April 2012 - 08:38 PM
QUOTE (bigblockbilly @ Apr 24 2012, 09:33 PM) <{POST_SNAPBACK}>
The pickups are all steel, no bumper extensions.
#37 ReDnekZ
ReDnekZ
  • 3,343 posts
  • Interests:Traditional archery, trucks, duck hunting
Posted 24 April 2012 - 10:01 PM
QUOTE (N2O_ZR2 @ Apr 24 2012, 08:38 PM) <{POST_SNAPBACK}>
what about the 94-97s?
#38 ducksface
Posted 24 April 2012 - 10:16 PM
Here's how to do a rolled pan on a Blazer
http://www.orrcomanu...om/ecc_abs.html
I didn't buy this because I want a rolled one without a license frame.
Edited by ducksface, 24 April 2012 - 10:26 PM.
#39 xtrmes10
xtrmes10
  • 177 posts
Posted 24 April 2012 - 10:17 PM
QUOTE (ReDnekZ @ Apr 24 2012, 11:01 PM) <{POST_SNAPBACK}>
Nope still steel.
#40 N2O_ZR2
  • 22,118 posts
Posted 24 April 2012 - 11:04 PM
QUOTE (xtrmes10 @ Apr 24 2012, 11:17 PM) <{POST_SNAPBACK}>
Nope still steel.
Yes and no. They have some pointy plastic endcaps that fit over the corners of the bed.
