Anybody Try these motor mounts on this forum
Posted 11 July 2011 - 08:25 AM
http://bajacustoms.c...p...t&Itemid=80
Posted 11 July 2011 - 09:05 AM
I just bought a pair of these http://shop.synergyo...m?productId=181
everyone on here says they work great and there 50 bucks cheaper.
Posted 11 July 2011 - 04:31 PM
those will not work on a zr2
Posted 11 July 2011 - 09:05 PM
Posted 12 July 2011 - 12:09 AM
Brian,
Yes, they will work. Thanks!
Joey Sanchez
4wd Factory
1175 County Rd. 138
Hutto, Texas 78634
Shop 512-759-6267
Cell 512-739-1595
Email joey@4wdfactory.com
www.4wdfactory.com
Posted 12 July 2011 - 07:46 AM
Do you have any information to back up that statement? They look right to me, no different than what I put in my Blazer....................Why wouldn't they?
Brian- They will work just fine, go ahead and buy them if you want. Especially since tech support gives the thumbs up, you can always blame them if not. Thats what I bought for mine and they work great. I don't notice the motor sitting any diff, it's in the exact same place it was.
Posted 12 July 2011 - 10:42 AM
Posted 12 July 2011 - 01:34 PM
Those are nicely built pieces. If they were available a few years ago when I bought the Energy Suspension mounts, I would have bought them, only because my truck is highly modified and needs the strength this style of mount offers. But for a stock-ish truck, these are a complete waste of money over the cost of the Energy Suspension mounts. My Energy Suspension mounts have not failed or given me any trouble after 4+ years in there.
Poly bushing mounts typically transfer a lot more vibration than stock-style rubber mounts. That might bother some people too.
These style mounts are considered rigid because the poly flexes very little. If you make the motor mounts rigid and leave the transmission mount stock, you run a high risk of cracking your bellhousing or transmission adapter. Either all solid, or all flexible is preferred, not mix and match.
We are actually having this discussion in another thread right now.
Posted 12 July 2011 - 01:39 PM
I've been following both of these discussions closely. Would these mounts, paired with an Energy Suspension tranny mount, be desirable or would they not be a good enough "match" to prevent issues?
I'm looking down the road for the new toy... I'm assuming its mounts are all in good enough shape for now.
Posted 12 July 2011 - 01:45 PM
maybe.
Posted 12 July 2011 - 02:19 PM
You're all set, engine and trans mounts are ES already. Same setup I ran with no functional problems or failures, but the trans mount did show signs of excessive deformation when I took it part. The best thing you could do to improve it further would be an anti-rotate mount on the tcase.
Posted 12 July 2011 - 02:48 PM
Posted 12 July 2011 - 04:26 PM
I'll look into that once I've got the truck in my possession... thanks.
Posted 12 July 2011 - 04:39 PM
the zr2 frame is different that a normal 4x4 s-series. normal s-series have a 2 part motor mount system. the rubber mount that bolts to the block and a bolt on frame pad that bolts to the frame. In a zr2 application there is the rubber mount that bolts to the block and then the frame pad is an integral part of the frame. meaning it cannot be removed. meaning those mounts will NOT work on a zr2.
Edited by 6speedblazer, 12 July 2011 - 04:42 PM.
Posted 12 July 2011 - 08:53 PM
Posted 12 July 2011 - 09:17 PM
Posted 12 July 2011 - 11:14 PM
The ES mounts have steel "hook" type things that lock the two pieces together inside the poly so they can't pull apart.
Some transmission companies actually recommend poly trans mounts when using solid motor mounts. You need to have some give for chassis flex or you could split an aluminium trans case.
So did you actually put these on your blazer?
Posted 13 July 2011 - 07:14 AM
That brings up another good point that nobody has talked about yet in either thread - chassis flex. ZR2s are a lot better than some trucks that flex like noodles (old square body chevy fullsizes), but I'm sure it still flexes. I bet this was really a problem with the old muscles cars that had similar frame structure and often came off the line with one tire 6" in the air and the other on the ground.
Posted 13 July 2011 - 04:20 PM
A lot of that was in the rear suspension, the rear axle would want to twist and push the right side up into the wheel well. Now with sway bars and the traction bars that changes the instant center you can make them launch pretty good.
The do flex a little, I've fixed two little out dents on one of the quarter panels just to have them come back after one night at the track. I'm really worried on how bad the K20 is going to flex when I start playing with it.
Posted 14 July 2011 - 12:01 PM
lol, agreed. But we got a pair of these free when Baja was in "test phase" and got a store credit in exchange for time/labor/whatever. We were just jazzed to be working with someone like them. Install was easier than expected. The motor was out already and the torch did most of the work.
Sorry guys, I wasn't trying to be an ass or make an issue of it. Just tryin to say that with a little work, you can do a lot more than you think, if thats what you really want to do. (Chris-not that you of all people would need to be told that)
