Still fighting code 171 174 any ideas???
12 replies to this topic
#1 Zx12richard
Zx12richard
  • 198 posts
  • Interests:Zr2s and Zx12
Posted 01 May 2011 - 02:59 PM
Tried the vacuum leak thing 3 times used can of starting fluid each time around intake. Tried three different used mass air units.
Put it in shop they said fuel pressure at idle good but showing 25%lean,they found no vacuum leaks. Changed fuel filter. They were 95% sure it was mass air unit. I bought a new gm mass air for 300 bucks. They was wrong.
I read some about map sensors, so I reset codes unplugged map sensor. Truck physically ran better than it had in a long time. I run 180 miles and check three times. Only code came up was map sensor cause it was unplugged. No 171 or 174. So i thought hey thats it. I got a really clean map sensor from a salvage yard dont wanna spend 65 bucks and be wrong. Cleaned it with carb cleaner then installed truck coded withint 20 miles.
171 and 174 back. Filters a k&n and clean.
Other misc codes it originally had was random misfire po300 po102 maf.
Thanks for any help or thoughts in advance.
#2 Zx12richard
Zx12richard
  • 198 posts
Posted 01 May 2011 - 03:05 PM
Forgot to mention. I do have a problem in the heating unit that could be a vacuum leak. Could something in the hvac trigger the 171 174 codes. Could I plug the main hvac line and see if it recodes?
#3 jackn7
jackn7
  • 132 posts
Posted 01 May 2011 - 04:02 PM
QUOTE (Zx12richard @ May 1 2011, 01:05 PM) <{POST_SNAPBACK}>
I had the same codes showing replaced the maf sensor and still showed ses code (171 and 174) finally figured out it was the rubber elbow directly behind the air intake above the throttle body. It looked ok but was just loose enough to let air in. Did a quiclie repair job with a couple of hose clamps and haven't had a problem since.
#4 Zx12richard
Zx12richard
  • 198 posts
Posted 01 May 2011 - 06:23 PM
Thanks trying it. Can't hurt.
#5 Zx12richard
Zx12richard
  • 198 posts
Posted 05 May 2011 - 08:21 PM
Unplug map sensor lean conditions disappear. Tried a used map sensor and lean came back.
#6 rustyg
rustyg
    Wants 26 Bacons Now
  • 3,354 posts
  • Interests:Fixin' broke stuff. Drag racing with my beautiful fiance.
Posted 05 May 2011 - 08:41 PM
#7 Zx12richard
Zx12richard
  • 198 posts
Posted 17 May 2011 - 08:58 AM
Well my lean codes turned out to be fuel pump.Some of my random misfire was wires. Hoping new ac delco iridium plugs will make the rest to away. Looked like fouth of July under hood the other night when looking for misfires.
#8 Bobbing
Bobbing
  • 475 posts
  • Interests:Mountain Biking, women, computers
Posted 17 May 2011 - 09:43 AM
QUOTE (Zx12richard @ May 17 2011, 06:58 AM) <{POST_SNAPBACK}>
Fuel pressure was lower than 50psi?
#9 Zx12richard
Zx12richard
  • 198 posts
Posted 18 May 2011 - 07:32 PM
I didn't personally check it. Shop said it was right at lower limit. But fuel pump did fix it. Filter was extremely dirty.
#10 Slick1
Slick1
    #1 choice of mother's everywhere
  • 10,723 posts
  • Interests:Kickin' it oldschool.
Posted 18 May 2011 - 09:34 PM
QUOTE (jackn7 @ May 1 2011, 05:02 PM) <{POST_SNAPBACK}>
QUOTE (Zx12richard @ May 17 2011, 09:58 AM) <{POST_SNAPBACK}>
I was having the same problems with it running lean and bucking on me a driving like total ass. After replacing the fuel filter and pump it still did it and it turned out it was a tear in the bonnet (top part of the intake that clamps to the throttle body).
Tiny cause, HUGE problems.
#11 QuickSilverAWD
QuickSilverAWD
  • 326 posts
Posted 25 May 2011 - 03:16 AM
That's why you should upgrade to an AEM Bruteforce style intake like the one I have for sale. No worries about crummy factory restrictions and get better gas mileage.
#12 Slick1
Slick1
  • 10,723 posts
Posted 25 May 2011 - 10:21 PM
QUOTE (QuickSilverAWD @ May 25 2011, 04:16 AM) <{POST_SNAPBACK}>
Edited by Slick1, 25 May 2011 - 10:21 PM.
#13 QuickSilverAWD
QuickSilverAWD
  • 326 posts
Posted 29 May 2011 - 12:16 AM
