ok, so I've been asking people about their lifts and found a lift set up that I really like. 2" front superlift, 2" pa bd lift, 2" rear shackles. I figure that would give me about a 4" lift and then when I've got more money, I'd be going with 33s ( so it'd appear to have about a 6" lift). Does this sound right? I am a novice to lifts because my last s10 was a lowrider. I have found the bd lift, but I can't seem to find the 2" front superlift. Anyone know where I can get it?
mild lift?
Started by greendragonslim, Mar 15 2011 01:22 PM
6 replies to this topic
#1
Posted 15 March 2011 - 01:22 PM
#2
Posted 15 March 2011 - 01:25 PM
you will have to do a little trimming with 33's
and i havent heard anything stellar about the superlift, but im sure someone can give you a little more info on that.
the shackles can be a bitch to swap, but well worth it.......and the BL is easy but time consuming, also worth it though
if you get the BL, get some gap guards or else your ass end will look like garbage
#3
Posted 15 March 2011 - 03:47 PM
QUOTE (Byam @ Mar 15 2011, 02:25 PM) <{POST_SNAPBACK}>
What do the gap guards do? cover the frame and what not?
my combination should give me about about a 4" lift right? and then another another 2" higher stance with the 33s?
#4
Posted 15 March 2011 - 03:48 PM
If you live where they salt the roads body lifts and shackles are a pain.
Make sure you soak everything in PB blaster early and often.
33's don't always measure to a true 33" either. It depends on the brand.
#5
Posted 15 March 2011 - 03:50 PM
The 33's won't add another 2 inches if you got a true 33 they would add an inch. Since it 33" in diameter.
Gap guards cover the gap between the body and frame created by the body lift.
#7
Posted 15 March 2011 - 04:37 PM
QUOTE (GOBLUE @ Mar 15 2011, 04:54 PM) <{POST_SNAPBACK}>
thanks for all the info. I'm about to check out the link.
