Bad Thump in Passenger Front End
30 replies to this topic
#21 TrailTamer
  • 7,109 posts
Posted 08 April 2011 - 10:21 PM
Cv joint??
#22 ZR2MudSlinger
ZR2MudSlinger
  • 3,946 posts
Posted 08 April 2011 - 10:57 PM
QUOTE (TrailTamer @ Apr 8 2011, 11:21 PM) <{POST_SNAPBACK}>
Cv joint??
i have a brand new one installed, did it with the old one too
#23 gregg6668
gregg6668
    4 Zs Elite and a Raptor 700 Too!
  • 4,720 posts
Posted 11 April 2011 - 08:16 AM
QUOTE (ZR2MudSlinger @ Apr 8 2011, 11:57 PM) <{POST_SNAPBACK}>
Cv joint??
As I ask everyone who has problems with noise after installing CV axles.
Was the replacement an OEM or aftermarket rebuilt or new aftermarket?
#24 ZR2MudSlinger
ZR2MudSlinger
  • 3,946 posts
Posted 11 April 2011 - 04:44 PM
QUOTE (gregg6668 @ Apr 11 2011, 09:16 AM) <{POST_SNAPBACK}>
Cv joint??
OEM is what the shop told me, i know it was 240 dollars but i got it for free since that wasnt the problem
edit: i dont know if this helps or not but....... it was 85 degrees yesterday and i barely heard or felt the thump at all. so to me that means that it is temperature related for some messed up internal part.
Edited by ZR2MudSlinger, 11 April 2011 - 04:45 PM.
#25 TrailTamer
  • 7,109 posts
Posted 11 April 2011 - 05:34 PM
With truck jacked up, turn the suspected tire by hand, do it binds a bit in some spot or thumps or whatever?
#26 ZR2MudSlinger
ZR2MudSlinger
  • 3,946 posts
Posted 11 April 2011 - 07:34 PM
QUOTE (TrailTamer @ Apr 11 2011, 06:34 PM) <{POST_SNAPBACK}>
The mechanic at the 3rd shop i went to did that and you can hear a slight thump behind where the wheel bearing would be.
#27 michphil
michphil
  • 191 posts
Posted 18 April 2011 - 09:19 PM
i know mine thumps from the passenger side,i checked everything and it turned out being rear passenger LCA mount,the welds are cracked making it thump along with some other weird noises,havent had time to fix it tho cause of work and shit,hopefully i can get it fixed soon before it totaly seperates deadhorse.gif
#28 ZR2MudSlinger
ZR2MudSlinger
  • 3,946 posts
Posted 23 July 2011 - 12:44 PM
well this noise is still going on only now it has started to whine, makes a high pitched oscillating noise. I took everything apart and nothing is broken, i dug down to the wheel bearing and it looks like it just came off of the assembly line.
CV Shaft is new
Upper Control arm is new.
Lower Control Arm looks fine, including the mounts
Doesnt get worse in 4wd
Ball joints are fine
Temperature changes makes a difference too, when its in the 60's it just thumps, when its in the 70's it whines and thumps, in the 80's it thumps slightly but whines loudly, in the 90's it whines really loud (sounds like moaning), over 100 degree's and you dont even hear it.
im stumped. I made a video, its in the 80's outside and you can hear it thumping, started whining after i made the video. At about 3 minutes into this video its very noticeable, before that you have to listen close.
#29 gregg6668
gregg6668
  • 4,720 posts
Posted 23 July 2011 - 03:08 PM
It's hard to tell any thing from that video but I still have to guess what I said earlier, just because you have a new CV axle in there doesn't mean it's the right one and it almost sounds like you have bad tires,what kind of tires are you running.
Try running a set of BFG LongTrails or some other smooth tires and see if it goes away!
#30 ZR2MudSlinger
ZR2MudSlinger
  • 3,946 posts
Posted 23 July 2011 - 07:08 PM
QUOTE (gregg6668 @ Jul 23 2011, 04:08 PM) <{POST_SNAPBACK}>
I am running a brand new set of Goodyear Wrangler Authority A/T's, i have gone as far as putting rims and tires (street tires) off of a 4 door blazer that my old roommate had and drove it around, and sure enough it still made it the noise. The cv shaft part number is a Napa Part number (NMD 959262 at $53.50 each) according to the sheet the shop gave me, the sheet also says "female end 26 splines, male end 27 splines, overall compressed length 23 3/8 inches"
Edited by ZR2MudSlinger, 23 July 2011 - 07:11 PM.
#31 kingbuzzo
kingbuzzo
  • 405 posts
Posted 23 July 2011 - 10:45 PM
I had a very similar noize last winter on the passenger front.
It was intermittent and only made the noize if I went over a jarring type bump (the roads are pretty bad here).
It turned out to be my lower ball joint was dried-out so we greased the sh*t out of it and it went away!
Damn gremlins - good luck...
