It will all ride UNDER the winch mount if you make the slot holes instead of those cuts shown in the picture. If it will clear the back of the bumper, it will clear that winch mount. The factory skid clears the mount when you trim two holes into one hole.
AND the only guy to confirm wanting one [so far] has a winch....
Just slip the skid in place, put the cross member/rear bolts in very loosely, and let the front of it drop about an inch below the mounting holes, while you're holding it up by hand. Picture bolts an inch longer and spacers. That's how it will clear the winch, you just need an inch of 'lower' in the front. While holding it by hand, look up to see the bolt holes. See? They don't quite line up [because of the one inch drop in the front] that's why you slot the front two holes in to one.
Honest, it's an easy easy fix, AND it will allow someone with a bit of frame horn damage to be able to bolt up the skid because of the slot instead of the two distinct holes....
Edited by ducksface, 23 June 2010 - 01:11 PM.
