My brake lights have stopped working, no fuses are blown. My tail lights work and so do the blinkers and reverse lights. I thought it might be the brake switch but the third brake light still comes on, what could be the problem?
Brake lights don't work but tail lights do
Started by ZRBaja, May 11 2010 04:54 PM
7 replies to this topic
Posted 11 May 2010 - 04:54 PM
Posted 11 May 2010 - 05:27 PM
change the bulbs
Posted 11 May 2010 - 05:35 PM
I changed one, but they both looked good. Changing the bulb didn't do anything. And if it makes a difference the trailer plug doesn't get a brake light signal either.
Posted 11 May 2010 - 08:51 PM
Check the green ground block near the frame on the drivers side at the rear of the bed (about a foot in) they tend to get loose over time.
Posted 28 May 2010 - 01:04 PM
i have the same problem and i changed all bulbs made sure all grounds were good and checked fuses what should i do next
Edited by 1996ZR2, 28 May 2010 - 01:04 PM.
Posted 28 May 2010 - 02:38 PM
might be your multifunction switch. any problems with your hazards? try fiddling with the MF switch and the hazards and see if you get any life out of the tail/brake lights.
Posted 28 May 2010 - 11:35 PM
QUOTE (Wolfpack @ May 28 2010, 02:38 PM) <{POST_SNAPBACK}>
all my lights work but when i apply the brakes they dont come on but the third brake light does. do u think the turn signal switch could be a problem
Posted 29 May 2010 - 05:28 PM
It turns out that it was my turn signal switch. Good call wolfpack i just got it fixed about a week and a half ago and forgot to put it up on here.
