Grounding problems
11 replies to this topic
#1 Jordan
Jordan
  • 5,521 posts
Posted 02 February 2010 - 12:46 AM
I have had this problem with my lights going out, reverse lights, and still my head lights.(My driver side running light stays the same, Driver side bright is at a dim, Pass. and Driver side are are a dim, I guess searching for ground.) They havve power and fuse is good. Relays are good. I have cleaned all grounds I could find for these lights.
My dads chevy tech at his work cant figure it out and he gave me some diagrams. But I cant figure this on out.
Have you heard of this one? Where should I start looking?
Edited by Jordan, 02 February 2010 - 12:47 AM.
#2 gregg6668
gregg6668
    4 Zs Elite and a Raptor 700 Too!
  • 4,707 posts
Posted 02 February 2010 - 09:27 AM
When you say you cleaned all the grounds, did you check the grounding block that is under the battery tray?
#3 Jordan
Jordan
  • 5,521 posts
Posted 02 February 2010 - 11:47 AM
Yes and the grounds for fuse box.
#4 gregg6668
gregg6668
  • 4,707 posts
Posted 02 February 2010 - 12:10 PM
What is the condition of the negative cable coming off the battery?
#5 Jordan
Jordan
  • 5,521 posts
Posted 02 February 2010 - 01:28 PM
Clean, all coating still looks good no crimps in the wire.
#6 Jordan
Jordan
  • 5,521 posts
Posted 05 March 2010 - 03:47 PM
Do you know of this grounding relay or any grounding relay that will cause my headlights to search for ground?
Thank you.
#7 Jordan
Jordan
  • 5,521 posts
Posted 06 March 2010 - 04:27 PM
Its called "Headlamp Grounding Relay"
None of the part stores have heard of it.
#8 Jordan
Jordan
  • 5,521 posts
Posted 11 March 2010 - 10:09 PM
#9 beedle4
beedle4
    Dreams of switching to chrome wheels
  • 7,382 posts
Posted 11 March 2010 - 11:06 PM
Not sure?
Know anyonce with an S-series you could try theres?
#10 Jordan
Jordan
  • 5,521 posts
Posted 12 March 2010 - 06:25 AM
QUOTE (beedle4 @ Mar 11 2010, 11:06 PM) <{POST_SNAPBACK}>
Not sure?
Yeah, I might try my dads tonight, or buy on at the junk yard for 5 buck.
#11 Jordan
Jordan
  • 5,521 posts
Posted 18 March 2010 - 08:08 PM
So I went to dealer to find the relay, They never heard of it.
#12 Jordan
Jordan
  • 5,521 posts
Posted 30 March 2010 - 08:12 PM
So any adivce would be helpful since now I have no headlights.
