Edited by chad19, 03 January 2011 - 04:26 PM.
New update on the GMC
Posted 14 December 2009 - 05:59 PM
Posted 14 December 2009 - 07:51 PM
You can use any spring if you feel like making/moving mounts. I want to say that 44044's are around ~46" long. Stock chevy half ton springs are probably 56". Just guessing off the top of my head. I think either way 44044's are not the same length as stockers.
All depends on if you want to change the wheelbase, move spring mounts, etc....
Posted 14 December 2009 - 09:37 PM
8" lift springs to go spring under sounds ghey. Why? Any particular reason he really wants to be spring under? If it's all about the height, then he'd be much better off with something like a 44044 spring over. Plus those 8" lift springs will have about as much flex as my concrete driveway.
Posted 14 December 2009 - 10:41 PM
Posted 21 December 2009 - 06:53 PM
Posted 09 January 2010 - 05:31 PM
Posted 09 January 2010 - 06:18 PM
Posted 10 January 2010 - 04:51 AM
1.Clutch
2.Engine mounts.
3.Engine Install.
4.Hi-steer.and steering.
5.Warn lock-outs(finish driver side)
6.Brakes(finish driver side) and make brakes lines.
7.Re-locate leaf springs a little.
8.Trans. Crossmember.
9.Tom-wood high angle u-joint.
10.Heater Core.
Rear.
11. Need either really long (U-bolts, anyone have any?) or he is ganna do long shackles.
12. Brakes and make brake lines.
13. Exhaust.
Random metal and hardware. Im sure there is more, thats all i can think of.
Posted 10 January 2010 - 05:31 PM
Posted 10 January 2010 - 10:13 PM
flex it out to know the difference between fully compressed and fully extended and buy some shocks with at least that much travel
Posted 12 January 2010 - 11:12 PM
Posted 16 March 2010 - 12:15 PM
Posted 16 March 2010 - 12:17 PM
Posted 16 March 2010 - 05:18 PM
Posted 20 March 2010 - 02:01 PM
Posted 20 March 2010 - 03:23 PM
Posted 20 March 2010 - 03:53 PM
But it does look good. Should be tons of fun
Posted 20 March 2010 - 04:06 PM
Posted 20 March 2010 - 05:10 PM
Posted 21 March 2010 - 02:09 PM
