overhead console help (have been searching)
2 replies to this topic
#1 Konigstigerii
Konigstigerii
  • 765 posts
  • Interests:Wheeling, hiking, shooting/firearms, doing stuff with friends, etc...
Posted 09 July 2009 - 08:08 PM
I've been searching around trying to figure this out for a few hours, but the console I pulled out of a 2001 astro van, with the trip computer, has only 7 wires that went into the console, it has room for two more, but they are not used, all the diagrams I find, show 8 wires being used...it worked just fine in the astro van it came out of too... The wires it has according to a diagram I'm reading is
7:rap fuse supply voltage
8: ground
9: VSS
10: air temp
11: Instrument panel lamp fuse supply voltage
12: Led Dimming signal
13: Not used
14: Battery positive voltage (THIS is the one I don't have)
15: Trip computer/nav class 2 serial data
Now this is going in my 97 s10, but before I get into it I would like to figure out what is up with my console, why the wiring is different then the others, even though it worked fine in the astro van. Do I need to add the 14th pin connection? or is mine different and doesn't need it??
Also on my 97 I don't have the retained accessory power (rap) so do I just run a regular ignition-on power to this wire?
Thanks,
#2 zellers88
zellers88
    Exterminated
  • Exterminated
  • -5,225 posts
  • Gender:Not Telling
Posted 10 July 2009 - 12:57 AM
you can get the RAP from the stereo, thats what i did
#3 raven2510
raven2510
    WANTED: Avatar Title
  • 1,427 posts
Posted 11 July 2009 - 10:18 PM
its not gonna work in your truck. different BCM and its from a 01. your truck is a 97. only 98+ and pre-98 will work together.
