Upgrading The Big 3
130 replies to this topic
#121 jobee85
jobee85
  • 1,937 posts
  • Interests:Off-roading<br />Snowmobiling<br />Four-wheeling<br />Football<br />Baseball<br />Lifting weights<br />Working on cars/ trucks<br />Camaros<br />Corvettes<br />Chevy Trucks
Posted 22 October 2009 - 06:50 PM
I did. page 4 of this topic. I have upgraded the battery now though. but still side post.
http://www.zr2usa.co...o...28442&st=60
#122 ZR2nit
ZR2nit
    Typing...and still waiting.
  • 1,974 posts
  • Interests:family,friends,off-roading,hunting,MY GMZ,my wife
Posted 03 May 2010 - 10:56 PM
I finally got around to doing this. I did all 5 wires with 2 gauge. Noticed a difference. Stays at 14V and drops to 11-12 with 800 Watts of lights on. Going to do AD244 next. No way winch would work with my headlights,fogs,and 4 overheads on. Thanks for the help
#123 Macs05Z
Macs05Z
  • 245 posts
Posted 20 July 2011 - 06:42 PM
I just completed my big 3 upgrade today. After my V8 swap and the ford taurus efan install my in-dash voltmeter showed that I was reading at the mark between 9 and 14. This is when i have the a/c on max and with the fan on at a stoplight. I went to advance auto and bought 2 gauge wire and some eyelet connectors for the 2 gauge wire. First off I left all my stock wiring in place. I have an Optima redtop battery so I used the top posts for this install. First I installed one wire from the positive side of the battery to the alternator power on th eback side. Then I ran a wire from the negative side of the battery to the frame. Then I ran a wire from the block to the frame. I then started my truck up after checking all the connections. I cranked up the a/c and I was pissed to see my volts drop to the same spot, right at the mark mark between 9 and 14. Did I do something wrong. After reading through this post I saw where the pictures and the discription showed that the block ground and the frame ground need to go t the negative side of the battery. Is that where I messed up? I keep getting a p0300 and was told that a weak charging system could be a cause of this. I need some serious help guys.
#124 killian96ss
killian96ss
  • 1,067 posts
  • Interests:Car Shows, 4 Wheelin, Road Racing, Auto-X, Astronomy, Family
Posted 20 July 2011 - 06:56 PM
This is what I have on my Z.
These cables use 1/0 gauge copper cable for the starter cable, and 2 gauge copper cable for the alternator, junction box and jucntion box to fusebox, 1/0 gauge copper cable for the engine ground and 2 gauge for the body and frame grounds.
You have to upgrade all the cables in order for this mod to work, and I have yet to see anybody make a nicer set than Gary @ Innovative Wiring!
Steve
Edited by killian96ss, 20 July 2011 - 07:00 PM.
#125 6speedblazer
6speedblazer
  • 936 posts
  • Interests:cars, guns, and women. the three most expensive hobbies known to man
Posted 20 July 2011 - 07:31 PM
QUOTE (Macs05Z @ Jul 20 2011, 06:42 PM) <{POST_SNAPBACK}>
try upgrading the cable from the battery to the fuse center.
#126 Macs05Z
Macs05Z
  • 245 posts
Posted 20 July 2011 - 08:38 PM
QUOTE (6speedblazer @ Jul 20 2011, 08:31 PM) <{POST_SNAPBACK}>
Thanks guys. I will try to add th extra wire to the fuse center under the battery tray. I didnt think of that. I ended up going to advance and picking up an AD224 145AMP alternator and swapped it in in the parking lot. So far it's better. I will test it tomorrow during the afternoon heat, with the A/C on Max and the high fans on. I really hope this is what was causing my constant misfire situation. It seemed to only happen when it got hot and when the a/c was on, so maybe the low voltage was the issue afterall. Thanks again for the input guys.
#127 Zr2freak316
Zr2freak316
  • Exterminated
  • 5,556 posts
Posted 27 September 2011 - 01:45 PM
im wanting to do this mod has ANYONE had problums with this mod AT ALL
#128 Keviness®
Keviness®
    "Yer Keviness" (aka n00b Admin)
  • 11,560 posts
Posted 27 September 2011 - 07:09 PM
The only way you'll have problems is if you mess something up during install.
#129 Black Angel
Black Angel
  • 315 posts
  • Interests:upgrading my blazer
Posted 07 November 2011 - 08:33 PM
has anyone done this with a dual battery setup? i have the big 3 installed, runs great but wanted to add dual battery with painless performance dual battery control sysem. how difficult would this be since im not using stock cables?
#130 cknaffle
  • 16,114 posts
Posted 07 November 2011 - 09:30 PM
QUOTE (Black Angel @ Nov 7 2011, 08:33 PM) <{POST_SNAPBACK}>
Yup. The painless system is a lot of money and complication that is definitely not necessary.
#131 Black Angel
Black Angel
  • 315 posts
Posted 07 November 2011 - 10:02 PM
QUOTE (cknaffle @ Nov 7 2011, 08:30 PM) <{POST_SNAPBACK}>
ive had the system sitting around for awhile. im thinking about installing it now, while im adding an amp. but the more i think about it, the more confused i get.
