May 30 2007, 09:04 PM
![]() Group: Subscribed ZR2 Owner Posts: 70 Joined: 15-March 06 Member No.: 1,201 |
so i cant get my middle spark plug out on the driver side. the steering column shaft that runs along side the engine is in the way to were i cant get anything on the plug. this happen to anone and how did you going about gtting it out without taking the whole damn truck apart
May 30 2007, 09:40 PM
![]() Group: ZR2 Owner Posts: 113 Joined: 25-September 06 From: South Carolina Member No.: 2,433 |
You should be able to get it out without taking shaft out. I got mine out with no problems( other than scratching my arms to crap). A friend of mine has a 2wd S10 and he had to take shaft out. My shaft was out of the way enough for me to reach under and put plug in.
May 30 2007, 09:44 PM
![]() Group: Subscribed ZR2 Owner Posts: 1,434 Joined: 12-July 06 From: Auburn, IN Member No.: 1,949 |
go at it from the driver's side wheel well. Pull back the rubber splash guards
If you use an extension, it should be just enough room. |
May 30 2007, 09:45 PM
![]() Group: Subscribed ZR2 Owner Posts: 1,301 Joined: 27-September 06 From: Geismar, LA Member No.: 2,444 |
i broke the old spark plug end off and used a shallow socket to taket it off and used a open end wrench to put the new one on
May 30 2007, 09:49 PM
Pirate ![]() Group: Subscribed ZR2 Owner Posts: 6,096 Joined: 2-December 05 From: Albuquerque NM, Eddyville KY Member No.: 1,032 |
On my 2wd I had to take the shaft lose... On my Z, I got to it through the fenderwell, it really wasn't too hard... I just ended up ripping one of my splash gaurds all to pieces :(
May 30 2007, 11:10 PM
![]() Group: Subscribed ZR2 Owner Posts: 5,493 Joined: 4-July 05 From: Kennewick,Washington Member No.: 831 |
Through the fenderwell like mentioned above, Helps to remove the tire for more room but isnt necessary.
I used a spark plug socket, Different length extensions, and a wobble. Didnt have any real problems doing mine and can knock them all out in a half of an hour or less. |
May 30 2007, 11:18 PM
![]() Group: Subscribed ZR2 Owner Posts: 1,339 Joined: 12-November 06 From: N37° 04.104*, W 84° 02.480* (London, KY) Member No.: 2,760 |
I think we have an uncharted new problem. Changing Spark plugs This post has been edited by f9k9: May 30 2007, 11:52 PM |
May 30 2007, 11:33 PM
I see whats left of a T-case from that link. |
May 30 2007, 11:51 PM
May 31 2007, 11:38 AM
Barrel of Rum - Made In Ireland ![]() Group: Subscribed ZR2 Owner Posts: 3,461 Joined: 24-October 05 From: Dublin, OH Member No.: 974 |
May 31 2007, 05:09 PM
thanks, im probly just gonna take the shaft out instead of fighting with all the tools and crap. thanks for the tips
May 31 2007, 05:22 PM
![]() Group: Subscribed ZR2 Owner Posts: 3,258 Joined: 19-October 06 From: Sioux Falls, South Dakota Member No.: 2,594 |
sweet! i need to change my plugs, i bet they're still stock, how much is it for new ones? i should get AC delco right?
May 31 2007, 05:45 PM
yeah so just take the shaft out. definately easy and took about 3 minutes. one damn bolt and almost ashamed i didnt know about it to begin with.
May 31 2007, 05:49 PM
TPT - FAILBOT ![]() Group: Sponsored Member Subscribed Posts: 6,660 Joined: 21-June 06 From: Harrisburg, Pennsylvania Member No.: 1,754 |
You think S-Series are a bitch...try doing an astro van with a 4.3....what a royal pain in the ass.
May 31 2007, 05:56 PM
What?!? I can't hear you! ![]() Group: Subscribed ZR2 Owner Posts: 6,448 Joined: 31-December 06 From: Darien, Illinois or "Chicago Suburbs" Member No.: 3,044 |
do you know that you can just remove the "hood" from the inside then you can get to almost everything :bobbytrendy: |
May 31 2007, 08:36 PM
Dont let the steering wheel/shaft spin with it disconnected from the steering box. You will break the air bag clock spring i believe it is called if it is 180*/360* off from center and you turn it to lock with it reconnected.
Jun 2 2007, 08:39 PM
Hands off my nuts foo! ![]() Group: Subscribed ZR2 Owner Posts: 3,583 Joined: 9-June 06 From: SLC, UTAH Member No.: 1,585 |
I just did my plugs...
On the driver side I pulled the whole intake and box out of the truck so I could get down into there and I tore my hands to hell but I got all of them. The one that gave me the biggest trouble was #5 (the one closest to the firewall). Once I got the bright idea to pull off the wheel I found it was a straight shot to get into there. Also I had a swivel extension that looks like a short extension with a funny shaped male end that let the socket swivel a little. (I hope that makes sense but it was a life saver) For the middle one on the driver side, once I got the spark plug boot off I had no problem getting into there with the socket, with out that swivel it would have been a real pain in the ass. |
Jun 2 2007, 08:51 PM
Check out the tune up part # in the sticky in this forum. Ac delco double platinums
For the cap and rotor I got the Napa gold set, they had all brass contacts. They were echlin or something like that. The truck runs real smooth now. :) |
| Lo-Fi Version | Time is now: 2nd September 2010 - 09:57 PM |
