HOW-TO: Knaffle's Shackles install
109 replies to this topic
#1 TrailTamer
  • 7,165 posts
Posted 29 March 2007 - 10:55 PM
here i am, i noticed that lot of people wondering how to get these sweet, beefy shackles on the truck, SUV.
i got the shackles yesterday, and i just go ahead install it today in the morning, after 4 hours of madshoot.gif i had it all done! i can't be any happier cuz the rear end is even to the front end now.
this is done on the 2002 blazer, i am pretty sure that it can be done a bit different way, espically with pick-up.
NOTE- spray oil on your bushing few time before you change shackles
NOTE- i found out that its not worth it trying to remove the exhaust and body parts tempopary, BUT if you think doing this will help, fine go ahead, good luck.
heres what you will need for a shackle install clicky clicky clicky ( you will need 13/16 and 7/8 inch socket and wrench)
this is the shackles i am installing
gotta find a nice, flat area to work on, hint- good idea to try to find a place to work on it, know that where it will be wont be in way in future if you failed to get the bolts out later- parked in garage
i have its rear tires on the ramp to bring the rear end up ramp
VERY IMPORTANT- Block the front tires to prevent from it falling off the jack stand
tire blocked
put your trustworthy jack stands on front spring eyes
i used the wood block to lift the rear end off the ramps
after the ramps removed, i get my jack under the U-bolts to bring the axle up to push the shackles back- which to clears the gas tank for bolt slide out- clicky
heres a bit tricky part, i just needed to use wrench to get the nut loose (leave the nut on to hammer on), then i use that big breaker socket to turn the bolt (not nut) several turns (keep turning till it get less effort to turn the bolt) to loose it up (it did the trick), then just start pounding it out. BUT if you want, you can just get the top bolts off first. then you can lower the shackle to clear the muffler and body parts to swing the hammer on it. clicky idea.gif
other way it can be done is to do idea.gif this, closer look, on the pass side to get past the exhaust and pounding the clamp like in the photo, it worked like a charm, but to make sure you is using a old clamp that you don't care to destroy like i did to this, and it isn't straight any more
this is a bit of PITA to get bolts out, and new in also on drivers side, just be patience another
after you removed the old shackle, you will go pretty fast put the new one on, then use all muscle you got to tighten it (impact socket gun is too big to fit in to use it) right side all done, but looks at how different from the stock side on left shakira.gif
BEFORE
SIDE
REAR
34 1/2 INCH from floor to top of the flares
AFTER
3 feet from ground to top of the flares
Edited by TrailTamer, 12 April 2009 - 10:08 AM.
#2 Jigg
Jigg
    Synergy Offroad Owner
  • ZR2USA Vendor
  • 6,946 posts
  • Interests:Stuff...
Posted 29 March 2007 - 11:03 PM
Good work Brett. I've pinned this topic, i know a lot of people can use this.
#3 gregg6668
gregg6668
    4 Zs Elite and a Raptor 700 Too!
  • 5,581 posts
Posted 29 March 2007 - 11:38 PM
#4 jtg2004
jtg2004
  • 4,465 posts
Posted 29 March 2007 - 11:46 PM
#5 Juddelicious
Juddelicious
  • 307 posts
Posted 30 March 2007 - 03:52 PM
Awesome "How to" LS1MikesTruck.gif LS1MikesTruck.gif LS1MikesTruck.gif icon_appl.gif icon_appl.gif
#6 nmband13
nmband13
  • 3,265 posts
Posted 31 March 2007 - 10:24 AM
nice work, i might be doing this in the future, thanks for making a How-To
#7 jawallace81
jawallace81
  • 2,116 posts
  • Interests:Flying, Fourwheeling, Fishing, Working on my Truck.
Posted 31 March 2007 - 10:32 AM
#8 cknaffle
    grumpy old man
  • 18,841 posts
Posted 01 April 2007 - 06:46 AM
Awesome work. Thank you!
#9 ZR2nNC
ZR2nNC
  • 1,073 posts
  • Interests:Hunting, fishing (freshwater, salt water (inshore and off shore)), camping, hiking, 4-wheeling, shooting guns, pool and darts, college football and basketball, going to the beach, hanging with friends, eating at The Mash House, Carolina Ale House and Hooter's.
Posted 21 April 2007 - 06:55 AM
Awesome write up Brett icon_appl.gif , will be using some of this info when I install mine today. BTW, I noticed the dent in your rear bumper, how'd that happen?
#10 TrailTamer
  • 7,165 posts
Posted 21 April 2007 - 07:23 AM
I got this big dent from trying to pull a stuck ZR2 out of mud pit and I didn't see the tree behind me. Curse the tire and body design! Lol
#11 ZR2nNC
ZR2nNC
  • 1,073 posts
Posted 21 April 2007 - 04:25 PM
Well, got mine on today and I have to say, it was pretty easy. I changed out both shackles in about 30 minutes. This doesn't include the time it took to put the truck on jack stands and trying to figure out why one of the bolts Chris sent with the shackles wouldn't thread right. I had to look at the bolt closely to notice that it wasn't threaded, it just had rings cut into it so the nut couldn't go on. I just used one of the factory bolts in it's place instead. All in all, I'm extremely pleased witht he results of the lift it gave my truck and would recommend it to anyone. I want to thank Brian, Justin and Jake LS1MikesTruck.gif for coming over and lending a hand with the install. I didn't take any pics, since I did the same thing as you did and your pics say it all. Thanks again for the tips Brett. icon_appl.gif
#12 Griff
Griff
    Barrel of Rum - Made In Ireland
  • 3,461 posts
Posted 23 April 2007 - 09:59 AM
Hey Brett I was just curious where you mounted your air fitting for your Monroe shocks?
#13 TrailTamer
  • 7,165 posts
Posted 23 April 2007 - 08:56 PM
QUOTE (Griff @ Apr 23 2007, 09:59 AM)
user posted image
had it mounted in there and the gas station nozzles doesnt not hit it, i am happ with it! no problem so far, no leak also shakira.gif
#14 phortwunty
phortwunty
  • 1,576 posts
  • Interests:Snowboarding, fishing, my dirtbike, wakeboarding, golf, hiking, camping, any kind of sports, been playing poker since before it was "cool", going to the casino and making sure the local tribe has enough to cover the electric bill, the greener side of life, fermented grapes in a glass with some good food, good beer, women folk, local music, live music, being lazy, being active, and all sorts of other weird stuff...
Posted 10 September 2007 - 07:49 PM
idunno.gif Quick question, and I only ask because I want to make sure I am not missing something obvious...but couldn't you skip the backing the car onto the ramps part? Just jack up under the rear pumpkin and slide stands under the front eye. Is it beacuse your stands were to tall and you needed what the block woud give you in lift??
#15 STR8upMoto
STR8upMoto
  • 170 posts
  • Interests:motorcycles<br>camping<br>4-wheeling<br>just about anything outdoors<br>VA, TN, KY, NC, WV (home)<br>TX is too flat
Posted 21 September 2007 - 01:08 AM
you said that shackle was ugly, you should have seen mine on my 94 s10 (especially after I tried to pull a limb out of a tree with my truck and jumped the back of my truck 4 ft off the ground HAHA.gif )..(had to get a new hitch after that one) one side of shackle was completely rusted through and other side wasn't exactly immaculate either
#16 shovel
shovel
  • 2,548 posts
  • Interests:Slack, sardonicism, boots, orgasms, contemplating suicide
Posted 07 November 2007 - 08:03 PM
wait... what's up with the air chisel? http://trailtamer.my...m06&id=CIMG2978
#17 TrailTamer
  • 7,165 posts
Posted 07 November 2007 - 09:35 PM
QUOTE (phortwunty @ Sep 10 2007, 07:49 PM)
i cant get it high enough to put the stand jack without having the tire to touch the floor when just using my jack, at least its my jack, could be different from yours.
#18 TrailTamer
  • 7,165 posts
Posted 07 November 2007 - 09:36 PM
QUOTE (99-ZR2 @ Sep 21 2007, 01:08 AM)
haha, that got to suck! but at least mine still is ugly lol but still strong tongue.gif
#19 TrailTamer
  • 7,165 posts
Posted 07 November 2007 - 09:38 PM
QUOTE (shovel @ Nov 7 2007, 08:03 PM)
i used that air chisel that the bit on it acts as a chisel and hammering quickly and hard and i used it to work the bolt out of the bushing (wasnt easy to come out on mine, could be different on yours since ya in AZ)
#20 Benji87AZ
Benji87AZ
  • 15 posts
Posted 20 November 2007 - 10:53 PM
where did you purchase your shackles at?...online or at a local parts retail store?
