Clean way to delete oil cooler lines?
10 replies to this topic
#1 rapsure
rapsure
  • 53 posts
Posted 10 April 2017 - 11:58 AM
So I just purchased a 3 row champion radiator. The radiator is: http://shop.champion...ICKUPS-SKU-1826
The radiator doesn't come with the oil cooler/heater part and so I need to delete that portion from the remote adapter. What have others done that worked well and clean to delete the oil cooler lines?
#2 eshaw
eshaw
  • 555 posts
  • Interests:Motorcycles (harley davidson), bow fishing and my new to me ZR2.
Posted 10 April 2017 - 06:17 PM
Change it over so the filter mounts on the engine block.
Edited by eshaw, 10 April 2017 - 06:17 PM.
#3 StRaNgErOcK
StRaNgErOcK
  • 30 posts
Posted 10 April 2017 - 09:40 PM
would that part required be available on the astro vans...just unbolt and use ?
#4 rapsure
rapsure
  • 53 posts
Posted 10 April 2017 - 10:04 PM
Although mounting on the block sounds cool I don't like the lack of access. I have 4wd and so the access at the block where the filter would mount is something like barely accessible through the wheel well.
#5 eshaw
eshaw
  • 555 posts
Posted 11 April 2017 - 08:59 AM
If you want to delete the oil filter lines the only choice is to mount the filter on the block.  Access isn't that bad, a little pain in the butt to get at but it can be done even if you have a 4x4.  Some folks will say to get a remote filter setup but there again you're back to dealing with lines.  Use the search function and see what all is involved and whether or not it's something that you want to live with.
#6 Blackhighrider
Blackhighrider
    Pirate
  • 7,264 posts
Posted 11 April 2017 - 09:03 AM
This is the only part you need to screw the filter to the block.
Or you can make your own oil cooler lines that don't leak.
http://www.s10forum....s-fixed-343472/
#7 gsmobile2007
gsmobile2007
  • 4,174 posts
  • Interests:ZR2's, Computers, Photography.
Posted 11 April 2017 - 07:45 PM
As above, but if you make the lines use armored ones, otherwise that cheap adapter gets it done.
Edited by gsmobile2007, 11 April 2017 - 07:46 PM.
#8 Thunderbear
Thunderbear
  • 392 posts
Posted 12 April 2017 - 12:44 AM
Best cheap mod I ever did. Raised oil pressure on an old 4.3, eliminated the endless fucking seep of oil from those shitty lines, and actually made oil changes easier. Can't recommend it enough.
#9 rapsure
rapsure
  • 53 posts
Posted 14 April 2017 - 10:42 AM
So what I did was I used a brass 90 degree fitting and wrapped the oil cooler lines back. I also had to reroute the transmission cooler line to skip the radiator even though it has a transmission cooler.
The reason for the big radiator was I supercharged the Blazer and I needed more than factory cooling to keep the whole setup from over heating during hot summer days and working hard while running the A/C. From what I've measured I should be getting close to 240hp at the wheels.
#10 jderekt
jderekt
  • 2,847 posts
  • Interests:Hunting, shooting, reloading, wheeling, camping, fishing
Posted 14 April 2017 - 04:03 PM
So I am guessing your using an external cooler on your trans?
#11 rapsure
rapsure
  • 53 posts
Posted 20 April 2017 - 05:20 AM
I do have an external transmission cooler. I'm actually going to use the radiator transmission cooler too. I just had to purchase adapters so that I could attach the lines. The Champion 3 row radiator has so much cooling capacity that the transmission should stay cool regardless of load or outside temperature.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
