Blazer72
Method 502 VT-Spec Rim/Wheel
3 posts in this topic
Posted (edited)
Does anyone know if a Method Racing Model 502  VT-Spec 15x7, wheel with a 15mm offset and a 4.72' backspacing would work on a ZR2?  It would require using a 3/4 inch thick wheel adapator to change the lug pattern from 5x100 to 5x120. The rim comes in Black or Silver and was designed for a Subaru WRX. Please see attached two photos:
Thanks for your help.
Bill
Edited by Blazer72
Added additional information.
With the adapters installed,  that will give the wheel only about 4" total of backspacing compared to the stock 6" wheel.  Moving the tire out that 2" will give clearance problems on the front when turning.
Thanks for the help. Much appreciated! I will keep searching...
